Need advice with power voltage return for Mercury 200HP Saltwater EFI
If anyone can give me advice it would be very much appreciated. The outboard is a 2001. Last year I was having problems with my starter hanging up and staying on and killing my batteries. I replaced the starter solenoid or relay switch and that has seemed to correct that problem.
Now something is killing my batteries. The panel is showing 12-13 volts when the key ignition is switched on and or when the engine is running. My neighbor told me a good way to test is to start the motor and then unhook the negative cable to each battery and test. When I do this the engine shuts off. His advice is that there is something wrong with my stator because the engine should continue to run and supply enough power to keep it running. Can someone give me some advice on this and next steps before I have to take this engine and have it serviced?
Thanks,
TM
Thanks,
TM
