Re: 1989 Mercury 135 power steering a little sticky..
It was hydraulic steering, and the guy that had it before me did not do any maintenance at all. There are oil (zerts?) fill nipples all over the place and I hit every one i could find, and now the steering, trim tilt are finally starting to act and sound normal. I have had to go over this thing to catch up on years of neglest, but in all it is a stron motor. after 15 uses it keeps amazing me. There is still a little slop in the wheel, and I was wondering if there is an adjustment for that. It is a Teleflex hydraulic system.
oy this sounds like what I went through when I bought my boat...3 years on and I am still trying to catch up...
I have a teleflex hydraulic system as well. I don't know the best practices for this system, but once a year I open up the fill cap, fill, turn the engine end-to-end a few times to drain air, repeat, and it does the job well enough. I fill once per year because the system is leaking at the engine side and it's a low priority fix relative to everything else on the boat.
I don't do anything extreme, light left and right turns, straight on for the most part - so - ymmv.
What is the best 2stroke oil for this motor? what do u use in your lower end?
For the engine oil I use mercury high performance. Some swear by it, as far as I know it does the job. west marine sells their el cheapo 2-stroke oil that costs half as much; I used to use this stuff. el cheapo is still tc-w3 compliant, so take that as you will; I switched to the more expensive stuff anyways "just to cover my basis".
i use mercury high performance lower unit oil as well, and since you only need a quart, penny pinching does not make sense to me here. But again, it works well as far as I know
