Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
how to replace throttle cable
  • how to replace throttle cable
    How do you remove the throttle cable at the motor (1977 mercury 85hp)? I see there is some type of clip the throttle and shifter cables run through that i cannot get to release. I want to save some money and learn more by doing it myself but i'm feeling a little mentally retarded with this issue. I have the Seloc manual and do not see any mention of the retainer i'm talking about. By the way, should i post all my questions to a dedicated thread or doesn't it matter?
    Re: how to replace throttle cable
    go to this link i have a videu on how to remove the cable from the engine click the black box to play it http://www.facebook.com/gbushinsky#!...14118&comments
    • #3
      You will then have to remve the cable unscrew it from the linkage then you will have to remove the throttle and disassemble where the cable goes in and detach the holding mechanism and remove the barrels there as well reinstall in reverse order
      • #4
        So easy a caveman could do it, and in 12 seconds. Thank you sir!!
        • #5
          lol
          • #6
            Well that was simple and i found out the cable does work but it don't start to move till i move the lever about 1/3 of the way forward. Is this a characteristic of the Mercontrol or do i have a different problem...stretched cable...worn control? I took the control apart and made sure everything was like the pic in the manual. I took the control apart to check because i replaced the throttle lever previously.
            Back to Top
