I had to remove my lower unit to have some work done on the seals on a Mercury outboard 2000 225 EFI. I put it back on with what appeared to be pretty easy but after I got everything bolted back up I put my ****er in forward and spun the prop and it does the same thing as it does in nuetral moves freely in both directions with no clicks and so does reverse. Where did I go wrong? Everything appeared to have lined up and slid back with ease but obviously something isnt right. I had the shifter in neutral removing and re installing the lower uinit. Any thoughts or what I need to do to correct it would be appreciated.
Thanks
Thanks
