Please, any suggestions. I have '91 Mariner, 115 hp with single cylinder tilt/trim. It is located on a lift over shallow water and really hard to work on. The hydraulic pump motor runs for both up and down operation, but the outboard motor will only tilt down. It acts as though the fluid is being trapped obove the piston. I have tried opening the bypass valve and the motor will sink downward, but cannot be raised. Its not because of a strength problem because I used a eight foot two by four. Need to get it on a trailer so that it can be disassembled. How can I release the motor so that I can tilt it up?
