I have a 1969 Mercuy 650 lighning 65 hp motor. Bought the boat last year and remodled the inside. Motor sat for ?????? god only knows how long. Fixed a few things on the motor such as wires, plugs, throttle linkage, ect. Motor runs great. Had it in a mess tub and all kinds of gunk came out of the lower unit. Bought a manual and took the unit apart. removed bearing carrier. Everything looks good. Changed seals and went to put lower unit back together. Needed a special tool so i made one instead of paying 115 dollars. Tool works great. Went to torque the cover nut assembly to finish the project and the cover nut got to roughly 75 ft lbs of torque before jumping threads. The manual calls out for 210 ft lbs for my style of unit. the housing and nut are both made out of aluminum. is that the correct torque and if so can i get by with less? Threads look fine on housing and nut. Gonna try a new nut
