Bought a used boat with a 96 Merc 135hp 3 weeks ago ran it on the muffs and seemed fine, it had been sitting all winter in storage water tested yesterday for a good 30 min, ran fine, sat for 30 min and ran again for 10 min before going to load up and noticed a ticking noise like a transducer out of the water. Seemed steady didn?t change with rmps. I could feel it when I touched the cables going into the motor. I could also feel it in the gas line so I pumped the ball and it went away for a min. then came back. As long as I was pumping the ball a little it was gone. I also couldn?t get the ball to stiffen but I understand that is normal when the motor is running. I did this a couple times and it kept coming back but the motor never stalled, cut out or ran rough. I check the tank vent thinking vacume lock on the tank and that is clear, other ideas I found online are the primer ball check valves, fuel pump diaphragm or carbs. I am going to start by replacing the primer ball tonight but I am a little worried with my first fishing trip a week away. Anything to the fact that it happened only after being warm?
Thanks in advance!
Thanks in advance!
