Re: mercury xr6 150 will not start
Thank you all for the imput. I pulled the carbs and cleaned them. The floats and valves seemed to be good, but there were passages that were slightyly clogged and dirty. The engine now runs, but stalls out after a couple of minutes. I suspect fouled plugs as I am getting fuel on them. I have a service manual on the way in order to properly adjust the carbs. I did not remove or move the adjustment screws, do I have to synchronize the carbs and what exactly does that mean?
I just pulled my carbs after 3 years running and put gasket kits in them, mostly to closely inspect them by way of preventative maintenance. They were clean as a whistle, nothing at all wrong. That's the way they should be.
Where did the crud come from that clogged the carbs the first time. Probably rotten hoses or a dirty fuel tank. If you don't solve the problem, it will just repeat itself. Fuel starvation is about the quickest way known to burn down this power head.
Adjustments and synchronization are in the book. The carbs have to be in step with each other, and properly timed with the timing advance of the throttle lever system. Any time you mess with any of that, you should go through the whole formal linkage adjustment and timing procedure, commonly called link-n-sync.
hope it helps
John
