i just got a 45 hp mercury and it starts and ideals great. once i put it in to gear and throttle up it starts to bog down.
i put in:
new spark plugs
new flue lines and primer bulb
2 carb kits and cleaned both carbs (were pretty clean to start with)
compression test
125# on all 4 cylinders
pulled the spark plugs and check to make sure they were all firing. have not done a spark plug test yet. just pulled the plug and held it against the motor to check it they were firing.
primer buld will prime up and stay primed. so both needles are seating in the carbs.
what should i look at next?????
Thanks
AY
i put in:
new spark plugs
compression test
Thanks
AY
