lostinboat
- Oct 18, 2008
- 63
hi, I have a 94 mercury 75hp that has been running about 5psi water pressure at idle. at 3500 rpm i get about 10 psi, If I raise the rpm's above 3500 rpm's my water pressure drops to around 4psi until i lower the rpm's back to 3500 or less and then jumps back to 10 psi. this has just started as this engine has always run at about 12 psi at 5500rpm's. Could this be the water pump going? pee stream is strong. engine temp runs at 146 degrees Thanks for any help.
