i have been having this problem since the first of the year,
1. carbs cleaned
2. new stator
3. new trigger
4. fuel pump has been re-done
5. damaged reed re-placed
6. lync n sync done
did ohms test on trigger and stator, trigger checked out by factory specs, no reading at all on stator, timing checked and re-set to factory specs by mercury service manual.
runs the same with or with out the idle stabilizer!
could it be a bad stator?
1. carbs cleaned
2. new stator
3. new trigger
6. lync n sync done
