Pulled off the lower unit to change water pump. No problem. cannot get the lower unit to go into N on the bench. Did not have any problems before removal. Can rotate the LU shifter about 180 and go into R, but I have to hold it there. Put it back on the motor after a hell of a fight to get it to go the final 1/4 inch. Did not force it, but it took many tries. Bumped it over, but it is always in Fwd. Pulled it back off. Read that it should be in FWD prior to install. Looking down at the LU is FWD full CCW with a click? And then put the boat in FWD? That should work right? She does not want to go. Any tricks?
Thanks in advance.
Thanks in advance.
