Re: 225 optimax feul consumption
Before making a very large investment in a new motor, perhaps you should take a look at your boat set up, weight, and performance expectations.
Overall weight of your boat, how you have it usually loaded, can have a major impact on fuel use, as well as the speed at which you intend it to operate.
Some of the guys in the Prop forum have access to some very good methods of calculating hp/speed/fuel usage.
Engine HP goes hand in hand with fuel usage, power demands fuel, 10% of the HP. Period.
Carb, EFI, or Opti, a 225 of ANY type will use very close to the SAME amount of fuel as the others on the SAME boat hull and weighted load.
Buying a new motor in hopes of saving money on fuel is never cost effective until you first maximize your boat/motor set-up, i.e., toss out all the excess weight.
Hopefully you will look into this a LOT more.
If a dealer is pushing you into this so called 'improvement', find yourself a truthful dealer.
