kjspylite
- Jul 2, 2010
- 37
1989 Mariner 75 HP 3 cyclinder
I have an OEM repair manual but am having trouble diagnosing my problem.
I am only getting spark on the top (#1) cylinder. I was thinking it was the trigger so I checked Ohms. Did not get a reading on any of the coils (brown, white, violet to white/black). Measured with all wires removed from the switchbox. I though that was strange since I was getting spark on one cylinder. Is it normal to get spark on one cylinder but have your whole trigger toasted? Should I be looking elsewhere?
Compression is 120 PSI on all 3 cylinders.
Stator Ohms were within spec.
Tried 1)removing the black/yellow wire from swithbox and 2)remove yellow wires from rectifer to see if spark returns per CDI website, no luck.
Thanks in advance for all your help!
