Re: mariner 40hp oil sensor question
Yes, there should be no continuity when the thank is full (circuit open). But the problem isn't the sensor (or swith), it's usually the magnet inside the tank. It is attached to a floater and slide up and down as the oil level change, but it happen that it separate from the floater and always stay on the bottom of the tank, creating a continuous alarm.
To test it, empty your tank, connect the two blue leads, turn the key to the ?on? position and flip the tank upside down. If the alarm stop when the tank is reversed, your magnet has fallen and there's no other choice than a new tank...
This is for the magnet problem but i can't understand why you're getting the alarm only on high rpm?
