Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
35HP mercury outboard won't start, new to boating
  • 35HP mercury outboard won't start, new to boating
    Ok guys, new to the forums and about equally new to boating. I've fished my whole life, and finally have a boat of my own.
    Bought the boat knowing it has motor problems. Got a great deal, so that didn't matter.
    The motor is a 35 HP, serial # 6491xxx, which dates it as a 1984 I believe.
    Anyway, when I go to start it, it cranks, and cranks, and cranks, but won't start! It's almost like the starter doesn't have enough juice, or the battery is dying. The battery is fine, and I think the starter is too, but it's possible it's not. It sounds like when I go to start my car and the battery barely has enough juice to start it. The difference with my boat is is that it will turn over and turn over, but never fire up. The spark plugs have excellent spark. When the spark plugs are out (and the key is turned), it spins much faster and free-er.
    When try to turn the top by hand, it is VERY TIGHT, almost immoveable. My 3 buddies motors (some mercury, some evinrude) spin by hand pretty easily (all between 25 and 40 HP).
    Where do I start trying to figure out what is wrong? I am halfway inclined to think the head is warped or something, or the piston is swollen or the piston rod is bent, since it's so tight. The motor has around 115 pounds of compression on it, is this normal?
    Just trying to figure out where to start and what to do. Thanks guys in advance for all the help!
    Re: 35HP mercury outboard won't start, new to boating
    sounds like you could have some serious engine problems there..if it is noticeably harder to spin than other motors..could be someone forgot to put oil in the gas and damaged the crank..or bearings...how long has the motor been sitting?
    Free ignition troubleshooting guide http://www.cdielectronics.com/techni...ort-documents/
    You will need a DVA adapter http://www.usatoolwarehouse.com/usat...e/ESI-640.html First test compression, Second test spark with a spark gap tester set a 7/16 gap, Third check timing, next CLEAN your carbs properly,
    • #3
      since last spring (2010). i'm betting this is the problem, mainly because it seems like I was told this may have happened.
      I figured there was something semi major wrong. how do I go about getting it fixed, and what am i looking at spending? thanks a lot
      • #4
        My 35 had problems..it had no fire on the upper cylinder..it would turn over fast then slow like the battery was really low... turned out to be the switch box....
        if both plugs are firing & it spins easily with the plugs out, it sounds like a lack of fuel..if the engine has good compression expect it to be hard to turn..if it turns easily with the plugs out it is hardly internal problems in my opinion.
        • #5
          i can usually pick up a good running 80s model 30-40 HP motor for around $700 sometimes less..keep your old one for parts
          • #6
            so you wouldn't recommend trying to get it fixed?
            thanks gej i'll try that!
            if anyone else has anything else to add i would greatly appreciate it
            • #7
              You may be interested in this link
              http://www.louisianasportsman.com/lp...e_ad&id=271255
              • #8
                it doesn't show a price. is the one i have not worth fixing, should i start looking for another? plus, that's an awful long way to drive, lol.
                anyone else have any other input on what to check on this?
                • #9
                  the louisianasportsman.com link is simply a way of you getting some prices & passing some time....I'm not suggesting buying another motor..you need to trouble shoot this one. There are many people on here with high expertise levels that can guide you through the trouble shooting if you are the least bit mechanically inclined & are patient. Good luck on your project.
                  • #10
                    I am having the same problem with a 9.9hp merc.
                    • #11
                      I would not recommend you trying to rebuild your motor yourself unless you just want to do it to learn how..but your cheapest way out is to get a good used motor...or you could take yours to a good mechanic and let them take a look at it and give you some prices to fix..my guess is it will be in the $1500 range. but if they are good and do it right you will have a good reliable motor.
                      • #12
                        ok, I understand. Thanks!
                        wow, pricey! i want to know how to do it, and i'm not looking for the cheapest way out necessarily. maybe i'll just run it to a mechanic and see what he thinks.
                        thanks guys. if anyone else has anymore input, please post! thanks!
                        • #13
                          Alright boys, got some more information for us! I appreciate all the help so far.
                          With the spark plugs out, I still can not get the motor to turn by hand. I can with a wrench, but not by hand. There is definitely a rubbing/creek sound at one point during the stroke. It would ALMOST start this morning when shooting some starting fluid it in, but it just wouldn't all the way go. Does any of this info help at all? Thanks!
