Re: mercury flywheel
You can order the 237-7555A8 kit which gets you a stator,flywheel and starter but its about $700. It will be cheaper to get parts off a later model V-6 as they are plentiful, and can likely get all for around $350. You will need a starter as bendix shaft is different size, flywheel and stator which actually helps you as you are updateding from a 9 amp to a 16 amp.
