kennythejoiner
- Jan 10, 2011
- 2
I have a 2009 out board as title that will be 2 years old in March, last week when I went to increase speed it felt like it was only half speed.
Went back to port and went through all the usual things without finding the problem.
End up in the out board hospital and when its plug in it says it?s a failed coil that was replaced and it still won?t run at full speed, It then comes about that no 1 cylinder plug is dry and getting no fuel, the whole fuel system, and injectors are tested and cleaned.
It?s still not right when they went to check the timing it was well of by about two teeth as there is no adjustment on these a replacement was ordered when on the phone to the uk importer my dealer was told they have had this problem before. I have googled it and came up with a blank other than this great site.
What I want to know is this a common thing and what damage has been done to my outboard...
