Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
1977 Mercury 500 Thunderbolt 50HP engine harness and wiring harness rebuild
  • 1977 Mercury 500 Thunderbolt 50HP engine harness and wiring harness rebuild
    My wiring harness is shot. While trying to test for a shot in the key switch insulation was falling apart as well as the wires just breaking. I cut everything loose from the key switch which tested fine but looks like it is 30 years old (which it is) so I will replace it with a new push to choke key switch. I started cutting back the wiring harness to find good wire but I don’t think there is any. Just wire skeletons/remains. The harness is $230 (http://www.iboats.com/Wiring-Harness...view_id.174724) I previously rebuilt the engine side wiring harness and at that time considered just building it all from scratch getting rid of the engine and the wiring harness. Any gotchas to doing that? Looks straight forward. Just home runs for each wire to the switch as follows per the attached diagram.
    Red – Solenoid to key position A
    Black – Solenoid to key position D
    Orange – Switch box to key position E
    Yellow – Solenoid to key position B
    White – switched power from key position F used by the choke and other keyed accessories
    Gray – Choke Solenoid to whatever that is on the new push to choke key switch
    Brown – unused as I don’t have a tachometer
    Thanks
    Mike
