Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
2007 Mercury 25 horse Jet Drive
  • 2007 Mercury 25 horse Jet Drive
    Does anyone know how you go about flushing the system of sand, etc without taking it to the dealer every time?
    Re: 2007 Mercury 25 horse Jet Drive
    what is the dealer going to do?
    the jet pump will run sand from the intake out the discharge and other than some wear should not hurt anything. (check with www.outboardjets.com)
    The sand going from the water pump into the engine is not good on the water pump, but if ran in fresh clean water after the incident should flush most all sand from the head and pee tube.
    If it has a T stat, pull it and see if any sand is in the area, clean with air the pee hose and back flush the engine. If any sign of restricted water flow from the pee hole appears, replace the water pump impeller and housing if it shows signs of wear.
    • #3
      How do I go about "back flushing" the motor?
      • #4
        Here is a site that will cover your back-flushing question:
        http://www.sschapterpsa.com/rambling...aintenance.htm
        I'll keep pulling on the towpath.
        You keep floating on the river.
        Yeah, until the day is done. ~ Clutch
        Back to Top
