vintagecamping
- Apr 19, 2009
- 13
I just got a 1964 Sabre Craft with a 64 1000. The engine hasn't ran in three years. I worked the engine with a wd-40 soak and turned it over by hand for a few days. Then with the starter, then with the plugs in. It cranks great with even compression sound. So I hooked up the fuel set the choke and it popped off and started. ( i shut it right off ) WoW. I need to know whats the best way to test run this motor? Should I use a drum or garden hose adapter? What type of adapter? Should I do anything different with the fuel mix ratio? Thanks
http://picasaweb.google.com/hotrodnova/MarcSBoats?authkey=Gv1sRgCMG_74SrzczCBg&feat=directlink
