i bought this boat 4months ago.it ran great,but it still had oil injection hooked up so i removed it useing manual and partslisted,i dont think my problem is related but might be so im adding that info.it started hesitating while running but only for a second and only once a trip,then it lost power on about the the 2nd trip after the removal.lasted 10mts,it acted like it dropped atleast 2 cylinders.now it does it every trip after running it a few minutes,it might clear up and run fine for a few minutes than cut out and stay that way till i get it back to pier,never does it cold and feathering the throttle gets it cleared sometimes but not every time.when it does this i do smell raw fuel and it does seem to foul plugs,,,but it is firing ,ive put in new plugs while its acting up and it will run a few mts and do it again.coils are firing and ive put on plug wires, all filters 3 sets of plugs.i cant figure it out,i thought it might be a weak fire but its firing blue.50;1 mix and bu8h plugs.the motor runs great but then this happens and thats it.when the boat is running good i can pull number 2 wire off plug and i cant notice a drop in rpm or sound change but the boat does lose power doing this . ive done this and than gassed i and it want pull but the number 3 cyl will shut the motor down when i pull it,so i moved that coil to the 2 position but no differance,might not be related.
