Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
How hot should the water discharge from the pee hole be?
  • How hot should the water discharge from the pee hole be?
    I have a 1998 Mercury 150 HP with Thermostats. How hot should the water coming out of the pee hole should be ?
    Re: How hot should the water discharge from the pee hole be?
    uncomfortable, but not scalding. (150ish)
    • #3
      Shouldn't be so hot as to scald you but should more than just lukewarm after running under load. Do you think there is a problem with yours? Until the tstat opens the stream would be rather cool in comparison.
      • #4
        Thanks for the info.
        It is just like that..... Uncomfortable but not scalding.
        Back to Top
