westexasrepublic
- Jun 17, 2009
- 524
1979 model,
This is the information leading up to the problem.>
I sold this guy my old boat, which I replaced all the electrical on the motor mentioned, parts replaced.
>new Wiring harness on motor
>3 coils
>switchbox
>trigger
>stator
>plugs and plug wires
>rectifier
after replacing the motor ran strong and started like it should, very strong spark and good compression on all 3 cylinders.
now the problem, The guy lost the only key and instead of getting a used one that fit he took it to a place with no experience and thye wired in a new ignition while still connected to the battery sparks flew (so he said). longer story short, the old ignition is wired back on after sparking the wires a little more and he found a key to fit.....(judge the guy all you want, I did) but he's now paying me to fix it so im trying my best without having to reorder all those electrical parts.
I tested the coils they tested good according to the Seloc manual, I replaced the rectifier after it tested bad (assumed it fried from all the fireworks)....
Now why am I not getting any spark? do the ignition switches fry as easily as rectifiers? and if so, would it still crank the motor just not send a spark?
>3 coils
>switchbox
>trigger
>stator
>rectifier
