Re: no spark,. stator ,mercury switch
so do i need the rectifier
Only if it tests bad.. it has nothing to dowith you not haveing spark...
the new one has a coil wire with it .does the new one have the switch box and the coil together ?
Yes it a replacement kit...
Before you start throwing part at it test the ignition to find the failed part, Below are test and hints to check your engines system.....
The acceptable voltage range for battery type ignitions is typically 9.5 Volts (at cranking) to a maximum of 16 volts at full throttle(13.2-14.6 preferred). Voltages above or below this range can cause damage to the CD.
DO NOT USE A MAINTAINENCE FREE, DRY CELL OR AGM BATTERY WITH ANY BATTERY DRIVEN CD UNIT!
No Fire on Any Cylinder:
1. Clean all battery connections and engine grounds.
2. Disconnect the mercury tilt switch and retest. If the ignition works properly, replace the mercury switch.
3. Connect a spark gap tester to the spark plug wires and check for fire on all cylinders. If some cylinders fire and not others, the problem is likely in the distributor cap, rotor button or spark plug wires. Notice: If the unit only fires when you let off of the key switch, the trigger is usually the problem.
4. If the trigger is one manufactured by CDI Electronics, verify the disk used in the trigger is the steel disk ? not the copper one.
5. Check voltage present on the White wire at cranking. It MUST be at least 9? volts. If not, the problem is in the harness, key switch, starter or battery.
6. Check voltage present on the Brown wire at cranking. It MUST be at least 9 volts. If not, the problem's likely in the pack.
7. Check DVA voltage on the Green wire going to the coil. It should be approximately 200 volts at cranking.
8. With the spark gap tester to the high tension lead coming from the ignition coil, disconnect the Brown, White and Black trigger wires. Connect a jumper wire from the terminal for the Brown wire to the terminal for the White wire. Connect another jumper to the terminal for the Black wire and (with the key switch turned on) strike the jumper against engine ground. The unit should fire each time. If it does, the CD module is usually good.
