Serial #1456136. Just where is that rascal? I dropped the lower unit and not sure what to take apart now. Is that impeller available? How about the fuel pump? Thanks.
The impeller may be a merc dealer item, my 62 6 hp impeller used to be sold by sierra but not anymore, I bought a NOS one at a dealer. Call East Coast Marine if you need help with parts.
The impeller is under the pump housing, black one held down by 2 nuts, drive shaft sticks up through the housing.
Thanks but where is the pump housing? I have the lower unit removed and that just has the drive propeller bearing showing. (not sure if I'm using the right words). There is no drive shaft exposed. Do I have to remove the tower from the powerhead or?
