hocuspocus
- Oct 17, 2010
- 3
I have bought this nearly new 16 foot boat, with 2008 EFI mercury 60hp. The boat was great this summer. I took it out one last time before winter and it was running fine at idle, low speed, just as usual. It usually planes out at mid-throttle (4000 rpm), but today it would not. It was just dragging low in water, 8-10 mph maybe. Then the engine winds up, but I backed off throttle not to overspeed. Power is not there. I would try again and again, but every time same thing happens. Can't bring the boat to plane, and the engine winds up as if the impeller would not follow or if it would fall in neutral. But it does not fall in neutral since the boat still goes forward, low speed.
Your help is greatly appreciated.
