donaldboyer
- Oct 15, 2010
- 26
1998 Mercury 90hp
3cyl 2 stroke
Hello,
I noticed the fluid in the power trim reservoir is a little low and I want to top it up. The manual says to use:
ATF fluid Type F, FA or Dexron II
I have some Penrite ATF fluid here which says it can be used where GM Dexron II spec is required.
This might be a dumb question, but is GM Dexron II and Dexron II the same thing?
Can I use this to top up my power trim??
Thanks,
DOnald
3cyl 2 stroke
Hello,
Thanks,
DOnald
