Hi out thier I have a 30 hp mercury lower unit I opened it up to replace the seals and there is a ton of corosion and everything is stuck is there anything I can do to remove the corosion or losen things up? Or will I have to run this lower unit with bad seals till its ruined and go find a new one? If its possible I would perfer to be able to fix up the one I got esspecialy since I already have the seals for it. Any advice is appreciated thank you!
- Tyler Zonca
- Tyler Zonca
