glastron fan
- Sep 3, 2010
- 3
I have a 1979 70 hp 3 cyl mercury outboard. my problem is that it won't let that reverse lock down on the bar clamp on the transom tilt pin when I shift into reverse and GENTLY try to back away from the dock The engine will jump up then I try to back it off & the motor slams down. I have just put in a new cam reverse lock & mew water pump etc. & checked the cam vs what the manual says it's right but there is an actuator rod that looks like it may be bent I dont know because if it was straight it would not make the angle to hit that rod at all. Does anybody know if there is an adjustment for this? thanks for your help
glastron fan
glastron fan
