Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
90 hp mercury fuel enricher
  • 90 hp mercury fuel enricher
    Help with the fuel enricher on a 90 hp mercury. I tested the fuel enricher by taking off the fuel line (one for the carb connection) and no fuel was coming out when pushing in with the key and in the on position. So I got a jumper wire and tested it off the starter solenoid and the thing will make a clicking noise now. I am thinking that the original positive wire is bad so I am going to make a new one and try again, but I am new to this and was wandering can the fuel enricher be gummed up and it can be cleaned out? Also, the enricher is running off the starter solenoid so the starter would have to be cranking over for the enricher to actually spit the fuel out right? Any suggestions or helpful tips would be appreciated! Thank you!
    Re: 90 hp mercury fuel enricher
    The contacts in your ignition switch may be bad or a wire came off.
    "A manual is a cheap investment"
    Fair Winds and Following Seas
    Bill
    PTC USN ret
