My 75hp is not registering speed anymore on the speedometer. I have taken the tubing off at the lower unit (actually just separated it from a junction) and blown into the tubing and watch the dash speedometer, it moves so i think that path is ok.
So my question is the part that goes into the lower unit, where does it go to? What or how should I check to see where the actual problem is. Is it common for the meters to go bad...or is it the part that is in the lower unit area that is bad
