Hope someone can help/advise me about my issue. Have a '80 Mercury 40 hp Thunderbolt. It's a 2 cyl./2 stroke with elect. start. I'll try to be brief. Boat & motor was given to me by my sister about 6 months ago. Boat itself needed some minor (mostly cosmetic) work. Motor was fine (per sis.). Over the last 5 months, worked on boat itself. Never tried to start motor during that time due to no battery, did periodically manually turn motor several times each to keep it freed up. Three weeks ago, boat finished, bought new battery, replaced old fuel (fresh fuel mixed 50:1) and cleaned tank. After about 15 minutes of trying to start motor, it finally started, ran a little rough at first(dog ears attached), but mellowed out. Worked throttle in forward & reverse, no problems noticed. Next day, put boat in water. Motor was a little hard to start, but started and idled okay. Under load and under way, motor performed amazingly well for something that hadn't been run in awhile! Have had in water twice. Problems that I have..after motor has been running awhile, it dies when in neutral at idle. Also, hard to start problem got worse. Now, motor turns over, but won't fire up. Have spark (at plugs, blue color). Pulled carb to inspect/clean, it looked alright, cleaned anyway. Fuel seems to be getting to carb. Any suggestions before I give up and take to mechanic?
