Looking for help to troubleshoot seized motor or lower unit:
I realized I ran out of oil at some time during my recent outing. This was evident when I returned home and restarted my engine to flush it out using muffs and garden hose (engine started and ran fine for the one minute of flush) After flush, I checked the oil reservoir in the attempt to top off and it was empty. It was full at start of outing... 1 gallon of oil and about 50 gallons of gas... so I do not believe I ran long without oil. However, this is a new used boat and I was not aware of the oil usage.
A week later I could not turn over motor (appeared to be seized).
I removed fly wheel cover and tried to turn flywheel using a 3 foot bar inserted between to 3 temporarily bolts installed in flywheel puller holes... there is no rotation either way.
I verified the lower unit was in neutral by the prop free spinning in both directions. In forward prop locks CCW and ratchets CW. However when in reverse it is locked up in both directions (is this normal?)
At this time I have removed all spark plugs and I am soaking the cylinders/pistons with Marvel Mystery oil in hopes of freeing motor.
Any help/direction would be appreciated. Could it be the linkage or lower unit is stuck?
Thanks
Thanks
