PrecisionVision
- Aug 4, 2010
- 3
I believe I posted this topic in the wrong forum. I'm so sorry! Please forgive my ignorance and I hope no one minds if i repost in the right forum (crossing fingers).
Greetings. I'm new to this forum so bear with me. I bought a Mercury 850 inline 6 that I don't believe is puming water. I've removed the lower unit and inspected the impeller and there were no cracks, dings, and it seemed to be in perfect shape so I did not replace it. I don't know how long the motor had been sitting before ran last, but it does run fine (after some negotiation). And to be honest, I don't see a pee-hole anywhere (unless it's a big rectangular cut-out on the rear of the shaft). It seemed like i was getting water out of the prop. Is that a good thing? How can i assure it's pumping water correctly? After running the motor for a minute or so and engaging the prop at about 1/2 rpm's (heck - i had to make sure i put the lower unit back together correctly!) i shut it off to find a little smoke coming out of that same rectangular cut-out i thought might be the pee-hole. Any thoughts?
Thanks for the help!
The amateur with a passion
