walleyemanII
- Jul 19, 2010
- 27
The engine runs fine up to about 3500 rpm but will not go above without surging. When you back off the throttle it will run find. I have rebuilt the fuel pump, replaced the fuel filter in the engine and fuel filter/water filter by the build in tank. I have checked the vent on the tank and it is open. I have replaced the tempo fuel line (failed) from the engine inlet to the filter on the engine. I have checked the carbs by removing the plugs by metering jets onthe first carb and it appeared to be clean. I have done a visual inspection on the stator and cleaned all of the button connections. The 2 voltage regulators have been replaced prior to me acquiring the boat and motor. The engine ran fine at first. I have burt off all of the old fuel and have added at least 2 treatments of fuel conditioner from stabil in the fuel. I have also replaced the plugs.
My need thing to check would be the fuel line from the tank to the motor then the tear down one of the carbs to check for contamination. I would not expect the carbs to be bad if the inline fuel filter did its job.
Am I going the right direction or should I check out the cdi packs?
