Hello everyone,
I need help on how to do the testing for the compression for this 115 hp mercury v6 outboard. I actually tried to do the test this morning and the number came out as below
Cylinder # 1 70psi when it is at 1000rpm and 130psi at 4000rpm
Cylinder # 2 70psi when it is at 1000rpm and 130psi at 4000rpm
Cylinder # 3 65psi when it is at 1000rpm and 120psi at 4000rpm
Cylinder # 4 70psi when it is at 1000rpm and 120psi at 4000rpm
Cylinder # 5 70psi when it is at 1000rpm and 120psi at 4000rpm
Cylinder # 6 70psi when it is at 1000rpm and 120psi at 4000rpm
Now I do not know whether these numbers are normal for this engine or not
I also don't know if I should start the engine when I test for the compression.
Please help. Thank you for reading this message.
