I think its a 1980 or 81, the S/N # is 2888354. It has not been started in at least 5 years and so I decited to change the gear oil in the lower unit and some other things to get it running. I pulled the upper plug (flush ) and the lower drain plug. Not much of anything came out. I started pumping in the gear oil and received some back pressure. The oil started seeping from a nut and bolt a little higher on the unit. It never came out the top hole. Im thinking it must have a clog or something. Can I use sea foam to loosen it? Can anyone please give me some advice. Thanks in advance.
