1989 115 HP Mariner fuel problems
Rudy's #1
I have a 1989 115 HP Mariner, had it serviced 2 years ago and have on not used it until this weekend, it starts with choke and stalls while idling, bumping the choke will keep it running, when at full throttle can only get approx 25 MPH versus 45 prior to tune up, if I keep bumping the choke at full throttle I can get it up to 35 MPH then it drops back to 25 MPH, I am definite it is a fuel problem but unsure where to start looking and route to go, do not have a manual or it either, any suggestions where to start, would fuel filter cause this? Any help would be greatly appreciated. Thank you inadvance
Rudy's #1
Re: 1989 115 HP Mariner fuel problems
Thanks, good advise and may do that route after tomorrow, tore into the carbs tonight, cleaned them out with carb cleaner (gunk) and blew out with air, checked out fuel filter which was OK, started it and it still would not idol so played with the fuel adjustments a bit on the top 2 carbs while choking it to keep it running and something broke free and it is now purring like a kitten on the earmuffs at idle and at 3000 RPM, taking it to the lake for the real test
