I was cruising yesterday at slow speed for 1/2 hour. Suddenly there was a steady loud intermittent beeping sound coming from the oil/overheat warning buzzer. I put the engine in neutral and revved the engine, then the noise went away only to return several minutes later. Back at the dock, if I kept the engine revving at 1600 rpm's( in neutral) the intermittent beeping would stop. Under 1600 rpm the alarm would sound.
I believe a steady intermittent beeping suggested an oil problem while a continuous non stop beeping suggests an overheat problem.
The oil tank is about 1/2 full. The smaller oil reserve under the engine cover was full. The screen in the oil tank was clean & not clogged.
The engine was not overheating (150 Degrees approx.)
I have never had this problem before. Is the oil pump going? How do I test the alarm which I can see under the dash.
Thanks for all your help & Happy 4th of July to all.
Sullmate
Sullmate
