superwooter
- Oct 12, 2009
- 167
i started posting about this problem in another thread, but the original topic of that post ended up not being the problem. here's the link to that thread for reference...
http://forums.iboats.com/showthread.php?t=398522
i've been dealing with this problem for nearly 2 months now. i get about 2 or 3 days a week to mess around with it. oh, this is going to be a bit long, but please read...
my engine had been idling rough, so my dad and i cleaned the carbs. it tested out great on the water muffs in the drive way so we took it to the lake a couple days later. once in the water, it would idle great, had a great hole shot, but once it got up to 4000 rpm, it would pulsate and not run up to 5000 rpm like it should. you could squeeze the bulb and it would push on up to 5000 rpm. my first thought was we did something wrong in the carbs or that maybe we moved some crud around in the carbs and now the high speed jets are blocked. however, the symptoms sounded more like a bad fuel pump diaphragm. so, i ordered the fuel pump kit that included the check valves at the recommendation of ajgraz from here on iboats. this had zero effect on the performance and the problem persisted. next, i changed out all of the fuel line inside the engine case. about 2 months prior to the problem, i had changed out my fuel tanks, fuel line, bulb, filter and all connectors (metal connectors), so i figured i could rule those out since it had functioned perfectly for some time before my dad and i cleaned the carbs. the new fuel lines also made no improvement. at this point, i was pretty frustrated, so i took it to my buddy who is a boat mechanic. he said on the muffs everything checked out great (fuel pump, compression, spark). i asked him to go ahead and clean the carbs again just to make sure i did everything right and that some of the old fuel line hadn't been pushed into the carbs. after the cleaning, he said the carbs looked great and that he really wasn't sure what the problem could be. i tested it in the lake and the problem was still there.
at this point i noticed that the molded plastic air tubes (not sure their real name) that go into the airbox had been in backwards. it has 6 tubes; 3 longer and 3 shorter. the shorter tubes should have been facing away from the engine to give clearance to the throttle linkage stop screw adjustment (see video and pics below). i don't blame my mechanic too much though because he put the part back in the way he found it. i put it in wrong before i sent it to him. i suppose i was on crack that day.
i had a fishing trip planned that i didn't want to miss, so we took the boat regardless of the problem and we just took turns pumping the bulb to get from fishing spot to fishing spot. between the lake test before the fishing trip through the end of the fishing trip, it got worse and worse. it was to the point that it would not run above 2000 rpm without pumping the bulb. as we were loading up the boat at the end of the fishing trip, we noticed that the fuel connector on one tank seemed loose. it turns out that 3 out of the 4 connectors i had, had gone bad. i suppose that all that bulb pumping could have over-pressured them and caused them to lose their seals. yesterday i replaced the connectors and filter again and tested it in the lake. it is still falling on its face but i could get it up near 3000 rpm without pumping the bulb. it still idles great and has a good hole shot up to 3000 rpm.
my guesses (at this point, that's all i have) are:
1. maybe the airtube piece somehow knocked it out of time and i need to perform link and sync.
2. maybe there's still something wrong with the fuel pump but i have no idea what.
3. maybe there is still something blocking my high speed jets in the carbs.
i'm about to the point where i want to put a few rounds of .45 acp in the thing and call it quits, so please help me to NOT do that!
here's a few pics and a video...
video link (click it)...
throttle in neutral (notice the idle stop screw never bottoms out)...
throttle at full...
throttle in neutral...
throttle at full...
throttle at full...
throttle at full...
