i have a 1999 16' alumacraft bass boat w/a 50 HP 4-stroke Merc on it and recently I have been having this problem:
When I start the engine, she sounds great... however, when the engine gets warm, it sounds/feels as though I am loosing one of the cylinders. You can distinctively hear the engine studdering or spuddering as it sounds like only 3 of the 4 cylinders are firing. Every so often, I can hear a click/tick sound... at that moment its like something clicks in the engine and and that fourth cylinder works perfectly again.
I have no idea what it could be as I am limited in my knowledge of engines.
People have said that the engine may be getting choked out... that I may need a new air filter or fuel filter... or that the choke may be stuck in the on position/or it keeps sporadically choking the engine making it not run smoothly.
any tips or comments appreciated.
p.s. - I will be replacing the fuel filter/air filter and have already replaced the spark plugs. Engine has has a tune up in the spring - new oil/filter, and everything greased and lubed. Will update after I put the new stuff in.
