Greetings all. I'm new to this forum and have a Question I'm pretty sure has been covered before but here goes... I have a 1980 Merc. 115(1150) w/ "thunderbolt ignition". Ie: distributor and coil. When I bought it it did not run but turned over. 135 compression across all cyl. Some threads say bad switch box, OR stator, Or coil etc...
Is there a set of simple troubleshooting test to eliminate each component?
I have no fire to any plug. Have 12vdc to switch box (wht wire) .
Any and all help would be appreciated.
