I have an older (1980`s) vintage 18 hp mercury outboard that was given to me and the motor starts and runs fine. I have only run it for a minute or so in a barrell of water to verify that the water pump is working.
Where on the motor would I expect to see the water if it was pumping coming from ?
On the back of the motor there is a series of 4-5 small holes and on the back of the cowl there is a hose running from the engine block to a fitting on the cowl - should water be coming out of any of these holes ?
Prior to starting I pulled the lower unit to inspect the pump (had been sitting for many years) and it looked to be in decent condition - any clues?
Thanks
Thanks
