rchafin294
- Mar 2, 2010
- 8
Serial # is 6548797. When I shift in to forward or reverse the motor will move at idle speed. When I give it more gas the motor revs up but continues to run at idle speed. This happened when I was on the water today I was going down the lake and all of the sudden the motor reved up and my speed reduced to an idle. I brought the boat home and put muffs on it and shifted into gear fine and the prop was spinning. I shut the motor off and turned the prop by hand and it turned the engine over. Before this the motor ran perfectly never any trouble what so ever.
