BassnKY
- Jul 30, 2009
- 126
I am trying to set the timing on my 84 Mercury 60. I got this off another post for setting the maximum spark advance. It seems logical but just wanted to get another point of view. Or, it the original poster (I don't remember who) could give me some help.
"Set WOT timing while cranking with the starter.
Remove all the spark plugs to reduce the load on the starter.
Ground all the spark plug wires, rig paper clips, alligator clips, etc., and wires to a good ground(s).
Remove the prop or be VERY CAREFUL of the spinning prop while cranking.
Use a remote starter button to trigger the starter relay/solenoid.
Rig your timing light on #1 plug wire.
Set throttle control to WOT in Forward gear.
Hit the starter button, crank the motor and observe the WOT Timing, adjust as necessary.
WATCH OUT for that prop if you didn't bother to take it off!"
I tried this on my 60 and it is showing at 10+ ATDC. The engine starts and runs good so, I assume I am doing something wrong.
