I have a 98 merc outboard (200HP, V6, OFFSHORE MODEL)...This is my issue.
The boat has been sitting for 3 years...Before running the boat I needed to change the water impeller (done), I also changed the plugs, drained the old fuel out of the internal tank, refueld with the recommended 50/1 oil/fuel mix and added STABIL.
Well, on the first trip, the boat ran fine for 2 hours. Ran it on high RPM and low RPM. After 2 hours the motor began to bog down and DIE when I ran it at high RPMs (4000+)
Today, I took the boat out again after noticing that a small black line with white stripes was broken, this line runs from the bottom of the manifold to the top (maybe a vacuum line). I replaced the line. The boat ran fine unless I got it over 4000 RPM again. I was out with a friend from 11 am - 6 pm (fishing and relaxing).
Any ideas of what this could be? I was thinking that maybe the high speed fuel pickup in the carbs are gummed up from the old fuel remnants. If this is the case, how hard is it to to rebuild/clean these?
HELP!
HELP!
