Re: Starters Blown 2007 90 EFI Mercury
Just a few seconds at a time, but I found the problem.
My negative battery post kept heating up.
I decided to replace the ignition switch and when I did,
I noticed not only was it wired incorrectly, the black ground
was detached from the crimp connector.
Under warranty a mercury machanic had replaced the switch last year.
Not only did he not check the wiring he patched into the existing
wiring. There were 3 connectors per wire on a 6 wire mercury switch.
I was not sure what to do, but I cut all of the wiring, and wired the new
switch matching colors.
The original wiring had black\yellow to black, I did black to black
and black\yellow to black\yellow.
Does that sound correct? The switch has push-to-choke bu the
4-stroke does not.
Installed new starter and so far so good. Probably 20 starts with
6 hours of run time this weekend. Negative battery post has no
heat.
