Been working on a fuel problem on this engine and seem to have it solved, but whilst doing the work i noticed that there is a brass T piece on the bottom carb that has no hose attached, on further investigation it shows in the manual that there should be a hose from the outer spigot on the thermal air valve to this T piece on the bottom of the lower carb, is this correct?
Anyway, what i found whilst working on the motor was that the outer spigot on the thermal air valve had the pipe from the top of the oil tank reservoir fitted to it.
I can not find a diagram anywhere that will show me what pipe/pipes should go onto the thermal air valve spigots, i understand that one is open with nothing attached.
I am a bit puzzled as to why there is no pipe at all from the thermal air valve going to the lower carb.
Can anyone help with what should be connected to the thermal air valve spigots, and also where the pipe from the top of the oil reservoir goes to, or is it open and not connected to anywhere?
Many thanks in advance of any help
Iain
Iain
