I know on some safety switches if they are removed/disconnected and nothing is put in its place it defaults to "not working" and the motor wont start. So if I understand correctly, all I should need to do is disconnect the wires and my motor should run correct? Thanks for your help.
Mine did, but it's a 1973 1500. Just make sure you're in neutral when you start it.
